I'm in desperate need to roll my front arches and just wandered if I could use a heat gun to mould the arch to where I wanted it. Without affecting the paint work?
Id honestly just let them rub through, Ive have on my Williams and my 172 and it will look far neater than if you ever took a cutting impliment to them. Is it rubbing in a straight line or just when turning? if its the later you are probably catching the bumper/headlight brackets and not the arches.
Did you trim your arches in the end? I've fitted some 30mm spacers and I think the tyres may be just touching now and again (strangely more with the T1R's on the road rather than the 888's on the track?!) so was planning to trim the arches a few millimetres with the Dremmel. Any tips?
