i believe the main rear beam is the same, but the stubs are different (don't forget the offset difference is there for a reason, ie 182 rear axle being wider)
182 axles are also stronger, if you compare them side to side they have extra strengthening around the shocks and springs. The also have a thicker 24mm roll bar..
