Are Phase II 172 front discs the same as on a Laguna?
Im after a set of front discs for a 2005 Clio 172 and was told that they share the same disc as a Laguna, is this true?
If so can you please tell me the part number?
Yes but not with all Lagunas. There is the same discs on clio 172-182-twingo rs-some megane II 1,6- some versions of laguna and some versions of scenic. Maybe there are the same with other models too, but I am not sure for the others.
With some mk1 Lagunas yes mate, be careful with the mk2 Lagunas as they use the same size 280x24mm front disc but have 5 stud holes...
I've sent brakes out to people in NZ and Oz before , guess it depends what you're getting quoted locally
