Are there 172 without Xenons?
  Clio 2 Ph2 K4J
Hello, after reading the forum trough and also the PDF stating all. I think you got xenons if you got the washer but all 172/182 non Cup/Trophy ecc should have them.
But it looks like my car has the Washer blanks in it. Can someone help me? Here is a photo of the dealer
Sash
  A Yellow One
Looks like it has had had some damage and needed a new front end and whoever has repaired it has replaced the xenons with standard headlights and forgotten to replace the washers.
  Clio 2 Ph2 K4J
I just looked at it and i get 1 Xenon Headlight for 270€ so 540€ Total and the question is what have they done with the washes? where are the lines etc… i wanted to buy this car next week but now im sceptical
Cookson
  Mk1 Audi TT 3.2 V6
Also, you can tell the front bumper has been painted as it's not got the little black inserts under the headlights.
I wouldn't bother with the washers, unless you legally need them in your country. Just get the blanks.
Sash
  A Yellow One
They do have a habit of leaking so maybe they just removed the pipes… or the washer bottle was damaged and they’ve replaced it with a standard mk2 bottle without the headlight washer pump?
I’d be looking for evidence of accident repair tbh.
  Clio 2 Ph2 K4J
But the Headlights are non Xenons right? Because im planning to do a diy cup pack (Bilstein B14s) and then the Cup wing and Lip. And maybe leaving the Standart Lights and buy some inserts for the bumper. Because i think building it back to xenon will be a pain.
Daz...
  Inferno 182 Cup
Those are the standard halogen headlights from a Cup or normal Clio.
The bottom grille has also been replaced with mesh and what looks like a whole tube of silicone.
  Clio 2 Ph2 K4J
Yes my father also said if he used a tube of window glue... I can get some ebay angel eye headlight with LEDS for 250 a Pair. i think if i want others that i put them in the car... i dislike the mesh grille i think i will spay it black... Maybe ill be able to lower the price if i point the accident damage out.
YorkshireKyle
Them wheels aren't standard, neither are the headlights, the foglight surrounds have been painted, the black stickers on the little slit have been painted, so has the bottom grille, so has the trim behind the diamond, so have the washer jets on the bonnet and the washer jets are missing from the headlights
Stevie Wonders guide dog is still in a job though
Daz...
  Inferno 182 Cup
105k miles isn’t high mileage.
But on condition and not mileage, it’ll be quite obvious is a car has been looked after properly or not.
  Clio 2 Ph2 K4J
This makes me doesent want to buy it anymore… my father also pointed alot of stuff to me
  Clio 2 Ph2 K4J
My father raced Reno for very long and he said if he needed a replacement engine he took one from a clio with 200.000km atleast they run better than the new clio engines haha. But yeah i think i go look at the one i send now.
  Clio 2 Ph2 K4J
Yeah, no idea on the standard spec there, but the Australian cars had 15" as standard
Im Pretty sure that switzerland had the same stuff as the French Clios had. But im going to look at another one today. 161000 KMS 6500€ And i get the OEM Renault Wheels and some Speedline SL2 in white. Plus he had Airfilter, Oilfilter, Oil, Breaks new, new controll arms, and new Waterpump plus Belt done at a Reno delaer.
  Clio 2 Ph2 K4J
The red one i posted above would give me the car for 5k instead of 6.5k the seat has a little hole, and the clock inside is missing, and the front bumper the thing where it says 2.0 16v and the roof is loosing the paint. But i would also get a set of wheels with it. There is also one with 130000 MIles.
My father is abit sceptial with the red one and says its smarter to take this one for 900 € more. What do you guys think.
