Audio (sort of) help
Knuckles
ClioSport Admin
I bought this cable a while back and it worked fine (after swapping the faulty one for a new one)
http://www.cliosport.net/forum/show...nput-fitting-and-centre-console-removal-guide
a couple of months later the cable stopped charging. No biggy, just a bit annoying. It still plays fine though.
Could the fuse be the reason it's not working?
Mine is similar to this but with a bit of wire rather than these 'S' shaped bits of metal
956730
i thought I'd ask here before taking the radio out to get at the fuse.
​cheers
Keith185
Could well be as the audio and charging circuit on the ipod connector would be separate. Doubt you'd need a gold plated fuse any 20mm fuse of right rating would be fine for a charging circuit. Sorry if I'm not of help only browsed your other thread :eek:
  1.2 16v clio
these fuses suck goat balls mate they are known to become loose inside and still look fine to the eye i had the problem were my amp kept on cutting out for no reason for it to cut out again and not turn on atall i checked the voltage to see it was reading 0.3v after changing it i haven't had the problem since
replace the whole fuse for an anl fuse mate
Knuckles
ClioSport Admin
can i have laymans terms please :eek:
and possibly links
So, if i fiddle with it, itll be a temporary fix?
also, can i do a pikey mod by packing it with foil to stop it coming loose?
Knuckles
ClioSport Admin
Right, cheers
So do I just chop the existing fuse out and fit one of those anl fuses?
and will the fuse have the rating written on it? As I'm sure the last time I checked it was blank
  1.2 16v clio
you replace the fuse holder and fuse but i would personally buy another fuse and fit it and see if thats the problem first
