What Auto Finesse say:
Dressle, the versatile all purpose dressing for exterior and interior trim. This water based dry cure dressing is the finishing touch for a multitude of areas all around a vehicle, from engine bays to interiors, wheel wells to intricate grills, adding a new look satin sheen and UV protection in one step.
Direction for use:
1: Apply 1-2 spritz to a microfiber cloth and spread to form an even film on the surface.
2: Alternatively for intricate grills, engine bays, or wheel wells apply by liberally spraying directly on to the surface, leave for 1-5min before wiping away excess with a clean microfiber towel.
3: For added sheen, apply multiple coats to achieve desired finish.
Available in 500ml & 5 Litre
Test:
I've been pushed for time recently due to a promotion at work and helping my sister move house so didn't have an opportunity to wash the car so please excuse the state of it!
I washed the trims I was testing the product on with a light spritz of APC and a wipe down with a micro fibre.
The rear wiper was used to show the results firstly:
Pre application
I then sprayed a small amount of the product on and left to dwell for 5 min before removing excess with a micro fibre leaving this, you can see the difference pre and post application with this 50/50.
It leaves a very natural looking finish, non greasy like many other trim dressings.
Full wiper done:
I also gave the mirror base and window rubbers a wipe down in the same way with again a nice natural finish being left.
My opinion:
I am not sure that this product will be added to my collection as I much prefer Auto Finesse Revive on the Clios ageing plastics. It does have its place however as I can imagine it would be perfect for addressing the complex grills on the clio with a simple spray on wipe off, I view Dressle as more of a 'trim quick detailer'
It does a quick boost of the trims looks very well but if I have out the time in to clean the car fully I'll stick with Revive.
The Air freshener is doing its job well, I already use these and you can expect a good 3 months of lovely sweet shop smell wafting around the car.
Direction for use:
Test:
Pre application
Full wiper done:
My opinion:
