AUX belt not lining up pas delete
Just got this in the post, the pulley is bent a bit so I cant move it over, you can see the belt touches the plastic cover. I have my other 182 alternator but the pulley is a different size, does that matter? And how do you get them off with a gun?
Also regarding tension, how much movement should the belt have?
Krarl
You need to move it over 1 rib mate
Like this
I'd try and take that pulley off the impact gun. If not I think you might be able to wedge the cooling fins enough with a big screwdriver to lock it off enough so that the gun bites
