Auxiliary belt tensioner issue
  2004 clio 182
Hi all i have an issue on my 04 182 then auxiliary belt is rubbing on the tensioner lower fixing below the spring on the tensioner i can't see any way to adjust this & have noticed wear on the flat side of the belt is this a common issue & how can I get more clearance
Many thanks in advance
Philip
Louis
I Love Ed Sheeran
Philip
Tensioners seized.
chazza114
Hi is this something that can be stripped & corrected os is replacement nesasary
Many thanks
Just replace it. They're meant to have a fresh belt and tensioner every 3 years so it's worth doing. If you leave it, you run the risk of the aux belt snapping, wrapping around the crank pulley causing all sorts of expensive damage.
