if your tyres are nearing replacement you will find it gets worse. Mine was doing it several times a day in the wet about 6 weeks ago. changed tyres and much better now. Just dont floor it in 1st, you can still pull away fairly quickly.
As sweltch says mine has got progressivly worse as my Toyos have wore down, after a few miles on a new set of Toyos I had trouble making the wheels spin in the dry and even sometimes in the wet too.
Just ordered a new set of uniroyal rainsports so I will see how they feel.
BenR, since I new what they were on about I thought I would answer with my findings on the above. It did tickle me too that it had been refered to as axle tramp.
Depends what your getting the banging from, could be from a multitud of things such as worn lower arm bushes, worn balljoints, top mounts, engine mounts, parts hitting eachother (ex manifold etc)......and in no real circumstance does a phenomenom like tram occur, you can get hop though.
Mine does it mainly in the wet. The times it has done it in the dry i have been pulling away whilst turning left. Hence the left wheel is light and it bounces (bang, bang, bang !)
I do get the same kinda thing on mine....when i fitted a rear strut bar (removed it in the end cos it didnt fit very well and made noises) it did stop the problem.
I took mine into R-sport and they say its something to do with the exhaust rubbing against something or something..., cant remeber what the guy said to me coz i was drunk last night so hazy recollection of events. They said they would order parts and I should bring it in again.
