Bad Earth
Car  Renault Clio MK2 1.2
Hi,
Just wondering if anyone can tell me how I can fix a bad earth on a Renualt Clio MK2 when i put the car into reverse the fog warning light comes on the dash board. also when I am indicating right the fog light also comes on also.
Hi,
Take the plug off each rear light and look for corrosion on the pins/plug terminal. Get some wd40 or proper electrical cleaned on the job and give them a dose of that.
Other than that it could be the earth points that are near the rear light unit. May need to remove them and clean them up.
I have cleaned the plugs with WD 40 when i take the earthing points of what do i need to clean. do i need to take the plastic bit of on the boot also? thanks
move the carpet and you'll see one earth for each light unit.
Sign up as a member and you'll have access to all this information and pictures in the guides section and other faults stuff.
