ball joint help for 182
Car  BG 182
In the process of changing bottom ball joints got the old one off no problems, offered up the new one and the ball joint will not slip into the hub.
Putting the new ball joint beside the one I removed there is a difference in size not much though, it is the 12mm bolt spacing one.
What's the story do I have the wrong part or do I need a can of man the *"&* up and open the hub more?
Like I said not much of a difference but is a little larger hard to get a decent photo, but it does not want to go into hub last one I done slipped in no problem.
Bolt the ball joint to the wishbone. use the pressure of the ARB to push it in...
Is the car on a ramp?
If so, try and wedge a crow bar in the slot where the pinch bolt goes through to open it up a tad, then spread some copper slip all over the inside of the hole and the balljoint itself
they are ment to be tight, and it can be a b*****d to do sometimes. Just gotta be brutal occasionally
