Banging when changing gear
Car  172 clio
I noticed this morning when I was stuck in traffic that everytime whilst in first gear, when I took my foot off the clutch to edge forward there was this knocking under the car - anyone got any ideas? Also in the lower gears my car was was making this high pitch whistling noise, once I was in third it went.
I have had nothing but trouble with the car - 03' 172 - new engine, toxic management system failed, the bearings in my rear wheels went after two years and then something was also wrong with the c-section and since they have changed that, there has been really funny noises under the car. I took it back but they said there was nothing loose, but seen as though everytime I take it to Renault something else goes wrong, can't say I trust them much.
Any ideas would be grateful.
Thanks Lou
sounds like the lower engine mounts a bit loose. had the same problem. does it knock if you floor it in 1 & 2nd then go quiet in 3rd?
If that is the problem then its just a nut needs tightning up so wouldn't bother going to renaults, anywhere could sort it out if you dont want to do it yourself.
I think mines coming loose again too lol
It does go quiet when I get to third, I will give it a little test tonight on my way home. Thanks for responding to my thread
