boot light is not working, so should i change the bulb? or do i leave it? battery was brand new, i think i actually had alternator fixed, but when i checked it it was runnning at 14.5. took sidelights out the other week, could that be a problem?
i would put money on it being the alternator draining the battery through a bad diode, had this on mine charged the battery fine but was pulling half an amp all the time the engine wasn't running. if you have a dc clamp meter clamp it on the alternator wire with all doors shut/engine not running it should be zero. if thats ok clamp it on battery positive lead and start pulling fuses until it goes down
