Battery?
Car  Mk6 Fiesta Zs
Disconnected it the other day to wire a wee sub in, but the cars been a weird wee fucker since. went to start it when i was at work on saturday n wouldn't start..2nd attempt..no problem! when just the ignitions on its became noisy as fook. the clock, dvd settings, etc keep re-setting as well. right in sayin the batterys due to kick le bucket?
Check connections. Check voltage on battery when ignition is on, when ignition is off. Think it's about 13.2V when on. Around 12v when off.
if you test the battery when engine is off should read over 12.5 volts any lower then the battery is slighlt discharged, should show 14.4 ish when engine is running. a fully charged battery should be 12.6. should be charged for 36 hours to get back to full strength.
