Bc racing too low at rear
Using the included 10mm spacer for the rear springs, I still don't have any arch gap at the rear!
I've set the front about 20cm lower than the rear, and I get about 5 cm arch gap at the front , looking really bad and assymetrical.
I don't want the front any lower than it is currently, to not hurt the roll center.
Anything I can do to raise the rear ?
  Clio 182
Think you might need to look at whether or not you've fitted everything correctly.....I have no problem with the rear being low on mine with the BC kit fitted.
Not sure what could have been done wrong ?
Rubber mount thing on buttom,
On top there's the Isolator spacer, 10mm spacer, piece that goes into the 10mm spacer, and top "hat".
BlackGoldMatt
  Tesla Model Y Perf
I have a set of rear spring adjusters if of interest? Taken out from my Bilstein B14's as the rear was too high!
