Best Ph1 172 Suspension kit
Car  ex-Fiat Coupe 20VT
Having had mine for nearly a fortnight now and not being happy with the wobbly back end over bumpy ground I'm looking at spend £600ish on a full shocks and springs kit for it. I'd also like to get hold of new bushes all round in that price too if possible to tighten everything up a bit. I'm not keen on dropping it too much, 20-30mm max. So what do people recommend?
Brewster
Koni yellows and Eibach sport/pro line for that price.
H+R for £700 plus another wedge for fitting is the next step.
Or personally new standard shocks with Eibachs is a good combo :)
I've heard the standard shocks don't last very long though :( I was assuming that was causing my bouncy, tail happy ride?
Hmm, I was assuming there was something seriously fubared with my suspension as when I go over smallish bumps the back end readily 'bounces' out one or two times. It was especially scary on a stretch of that concrete motorway. Almost fighting with it to hold a line! Seems fine on smooth tarmac, even when you really throw it into a corner. So would lightening my wallet to the tune of £600 sheets now not be advised.
Thanks for all the replies :)
IMO either stick with strock stuff as its better than most the cheap stuff out there or spend on H and R's etc.
I don't like KONI stuff much.
Save up a little bit more and get h & r's / bilstein coilovers fella.
Well worth it, you'll only want them eventually anyways.
