> the problem here is that 99 out of 100 people do not
> want to start cutting up parts of their car,
Maybe, but theres not really any reason not to...
If its for resale value, then it doesnt really effect anything... you wont notice if theres a speaker in there anyhow, even if you put the factory ones back in. Who pulls the speaker grille and/or door card off when theyre buying a car? It causes no structural damage.
If its beacuse they cant be bothered... well, it takes next to no effort, the hole is big enough already for a 6.5". YOu just have to remove a small plastic backing, which took me all of 5 minutes. If they cant be bothered, then they should stick with factory audio
> a set of 6.5" speakers will fit, however, depth IS a
> issue, you only have around 65-70mm clearance behind
> the speaker once the window is fully opened, which IMHO
> is not good enough for a quality mid driver"
Do you mean without removing the plastic backing? Because my boston pros fit in there with plenty of room. You can fit a space ring on the door behind the factory grille and fit just about any speaker you can find. Both the focal Utopia/K2P and the Boston Pros (old and new) will fit with room to spare.
> yes mike they are 13cm components, very good value for >
Well, Id still prefer a 6.5" speaker
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Something else to consider is Hertz (From the same ppl that make Audison amps) - they make very reasonably priced 6.5" speakers with a front mounted magnet, so theyre very very shallow. I dont know if they fit, since I havent tried them, but Id be nearly 100% sure they will. I cant remember the range name, but its easy enough to find on the web.
