Best Splitter for 182 NOT K-TAX!
  FF Titanium 182
So I bought a Carbon Splitter and the piece of s**t has been hit by a fly and fallen apart, whats the next best alternative? And what looks the best?
  Clio 172
Skoda Fabia VRS splitter and some carbon wrap if it has to be carbon! I just fitted the standard plastic Skoda splitter. Job done.
  FF Titanium 182
The standard cup splitters are still just as brittle! Do the fabia ones look good when on?
Flat Eric
Sing Hosanna!!
  F31 35d, Berlingo Na
They do the job
Depends how fussy you are
I have a carbon one, it's on it's last legs now though, one last refurb then after that I'm scrapping it for something else
GrahamS
  335d
Completely agree with the above. Why pay so much for something in one of the most vulnerable places on a car.
If you smash it then £12 to replace is a wonderful feeling.
Flat Eric
Sing Hosanna!!
I caught mine when parking a few months after returning it :(
I've sort of give up with looking after the splitter now
GrahamS
  335d
Yeah I only ever bent mine a little getting it on and off ramps.
It depends what you use your car for. Mine used to catch every morning on the carpark ramp at work so an expensive one would have been a terrible choice.
Used to be taken off when they were put on the car transporters when new
Jack!
I guess a lot depends on how low you are, I'm on Eibach Prolines, which are a very small drop - my splitter goes over the curb at my old works parking space.
  FF Titanium 182
As long as it looks good I don't mind, if I would have known about the Fabian one in the first place I'm sure I would have used that then pay k-tax for there diabolical one.
  Clio 172
Fabia looks ok. It's just a flat black strip of rubber, it just adds a nice bit if depth to the front end.
  FF Titanium 182
Yeah that looks mint mate I think I'm going to get one tomorrow! Are you running them 3/4 plates all the time? Ever been pulled?
  Clio 172
Not yet... But it's hardly been driven since fitting... So I will see how long it is until I get grabbed by the short and curlies for it! :/ I didn't know it would be so small until it arrived!
  FF Titanium 182
Ahhh got you, let me know if you do! Really want to get a set makes the front end look so much more tidy. Fabia splitter it is then! Need to ask them for a VRS one or just a fabia splitter?
  Clio 172
VRS I believe! I was lazy and ordered off eBay after searching "Skoda Splitter" it Was £17 delivered. If you go to Skoda it's £11 and you can collect it from them directly. Girlfriends brother got his from Skoda directly so saved £6!
  FF Titanium 182
Okay cheere mate I will ring my nearest dealer see if I can pick one up il ask for the VRS see what they say bargain really!
  Clio 172
£16.75 off fleabay posted. Saves fuel picking it up. How do you lot fix it to the bumper?
Its as simple as fil_b makes it sound really! :) I made a center line from my front Renault Diamond using some string and a weight and marked it up with a chalk pen, and then marked up the middle of the splitter by measuring it. Once I had the center lines I drilled a series of small pilot hole in the splitter to feed the self tapping screws through at regular intervals all along the splitter. After srewing the first one (The central screw!) into the bumper (It takes a little pressure on the end of the screw to get it to bit into the plastic of the bumper!) the rest just followed. You will need a junior hacksaw to trim the edges off the splitter, there is about an inch over over hang at each end, its soft rubbery plastic so cuts off really easy!
Jack
  FF Titanium 182
Found mine for £16.75 posted local dealer to me is about 10miles so the extra £3.75 was worh it.
