Better air intake for STD airbox
Sib
Car  Clio 172 (Silver)
I've heard about removing the acoustic valve, does this make airflow better?
And without loosing a fog light is there a better way to pipe the air in using an aftermarket hose?
A length of 63mm IIRC hose can be attached to the end of the trumpet that connects to the airbox. You can then run this down into the wheel arch where the acoustic valve and straight to the vent at the base of the wheel arch liner. Job done.
