biggest engine in a megane
Car  MEGANE COUPE MK1
whats the biggest engine or even the best engine i can fit in my megane coupe thats a prity strat swop thank in advace
F7R. F4R with Clio pistons or F4rt
Only f7r will go in without messing with the electrics and going standalone, but even that requires some fiddling
That's not even coherent??
sorry dude im dislexic i ment what car the engine is out of and what engine size im looking at a 2.0 megane engine but i was wondering if ther was say a 1.6 or 1.8 turbo or sumthing like that
ha very funy a 1.2 wont even go in this in less i did magor weight reduction and i was looking for a turboed engine or a engine to turbo about a 1.6 to 2.0 really a 1.2 would just die id kill it lol
Are you doing the work yourself?
can you wire in a standalone?
can you build engines?
are you any good with spanners?
You need to know if you can do all that before even choosing an engine. But as above plenty to fit in there only a handful that I've mentioned fit straight in on the mounts and all bar a 2.0 16v from a mk1 phase 1 will require electrical work
yeh im not bad with spaners and i can do most things with engine but i wont a engine that wiil fit strat in with new engine manegment and old looms its my every day car so i can only take off the road for a day or two
None then.
2.0 16v from a mk1 phase 1 (f7r engine) is your best bet. In which case you'd need a whole car for the engine loom and for the price of a Decent one your better off buying one and using it anyway
which engine do you have? 1.6 8v?
Because its cheaper to buy a 2.0 16v in the first place.
No there aren't many tuning options for your engine
Jaff is spot on...for the work involved, its easier and cheaper (if you factor in labour) to just get a 2.0 litre f7r engined Megane which came as standard...just DON'T buy the 'IDE' (Aids) engine version...
what do you mean aise engine
dont no its got a body kit on it lol
is there any lower comprestion pistons for the 1.6 8v like with the puntos you could drop the 16v pistons into a 8v block and it would lower the comprestion so you could turbo with a remap
You cant remap your ecu
no 16v heads. No pistons I know of. Only thing I know of is a stainless manifold that fits the head.
Yes that's an f7r (2.0 16v), its running on standalone ecu, I've had to build it myself, wire it myself and it takes more than a weekend to do
yeh i no that it dont take a weekend lol i was thinking of buying a old 1.6 engine and turboing it and droping in when its done but if there not meny tuning parts i might run it in to the ground and buy a new car in a year then this will be off to the grave yard lol its so f*****g slow 0 to 60 it takes for ever i thoght i was buying a sport car my old 1.0 16v micra was faster 0to6 lol but its done 138000 so its geting on may be sumthing wrong with the engine
yeh ill think ill just kill it and buy another fiat the so easy to mod ive just sold my old cinq that was crazy fast it did 2.0 gti lol
