Billet flywheel
Ph1 Tom
I'm planning my gearbox change soon if all goes well and I thought whilst I'm at it I may as well get a billet flywheel. Otherwise I'll have to buy a spare anyway and get it re-faced.
What is available? The one from ktec at £297 is a bit steep.
  182 cup
Billet is from what the lightweight flywheel is made from. Basically one lump of metal milled down and balanced
Advikaz
I've always found lightened flywheels a pain in the arse on the road as fundementally you are removing the mass that keep the engines momentum up. Yes it does feel more responsive but on day to day basis they are a pain for stalling.
Ph1 Tom
The standard one is fairly light already at 5kg. The billet one only saves 2kg.
You don't gain much in terms of acceleration but it helps a little with engine braking.
mikekean
  996 C4S, 135i, E30x2
My billet one has the standard timing marks on it?
I wouldn't put one in a road car tbh, makes it terribly jerky at low speed.
mikekean
Sprung Helix paddle, drives no different to a standard clutch once it is engaged.
mikekean
Tbh mate its not even that bitey compared to most paddle clutches. Pretty well mannered, could live with it in a road car.
Ph1 Tom
Having driven a few cars with lightweight flywheels with standard clutches and paddle clutches and standard flywheels with standard and paddle clutches I'd say it was the clutch rather than the flywheel that makes it jerky
mikekean
Well the only thing i have changed on my car is the flywheel, it already had a paddle clutch fitted and thats when it started becoming jerky. Doesnt make any difference to me as its on my rally car, but not sure id want to live with it every day.
  Ph1
I had mine lightened years ago and couldn't tell the difference although it was in conjunction with cams etc. I wouldn't bother tbh
GrahamS
I've got the billet one. Makes the idle rough but made it noticeably revvier. Not a problem with stalling and the bite is exactly the same as you would expect as it's a standard clutch.
Lightening the standard flywheel doesn't give results like a billet one does. weight of a lightened one will be circa 1kg less than standard. K-tec one is however much less.
I can take some photos if you want as I've got one in the garage I'm waiting to fit to a friends car.
