Bleeding brakes on a 182
I agree with fred so long as you let each one flow a fair bit of fluid out then it doesn't matter. The problem is most people don't let enough air run out particulay out of the rear brakes.
Cheers guys! Done the fronts already, pumped the pedal about 10 times. Does that sound like enough? Presumably would need more for the back...
^^^^ Its not about the amount of times you pump the pedal , its about when you pump the pedal that the fluid runs clear of any air bubbles .
