bleeding brakes
Car  www.renparts.co.uk
how do i bleed air out of my brakes on my 1.4 16v? pedal is well spongey, bearing in mind it does have ABS.... does this make it more complex?
thanks
josh
Got to halfords and buy one of there one person brake bleeding kits then assemble as it says and you attache it to the brakes reservior and open the caiper bleed nipples and let the fluid air out for a bit till you get a constant stream of fluid from the caliper then close the nipple up and do the next calipers.
Your supposed to do them in a certain order but it doesn't matter so long as you let the fluid flow through the caliper till you get a good constant stream.
fUbAr said:
dont get the fluid on the brake pads though!
if you get it on the discs, use brake cleaner after! :)
Or just drive it hard and burn it off like I do.
PS Don't follow my advice on this as I'm stupid and lazy.
