Bleeding valver brakes
Car  RenaultSport clio 172 mk2
Just a quick question, is there anything in particular that i have to do with valver bnrakes when bleeding them. changed the rear pads and bled them working from the rear passenger side, now ive got no handbrake at all, the cable is fine (quite new i think). Do i have to use the handbrake as well as the pedal when doing the rears ??
Nope.
Just make sure you let the fluid run for a bit after you get a constant stream and you don't have to do them in order realy either.
SOunds like you need to adjust the cambel have a look in haynes manaul how to do ti I think you unclub the cable on the caliper pull the calpe and caliper bit back and re-atach and they will work.
cheers eddie, the cable looks ok though, no slack in in but will give it a go tommorow, cant hurt, gonna beed them again in the morning, thing is its got brake but no handbrake if you see what i mean !! :dapprove:
