There are two outlet sizes listed on DT: 70mm and 85mm. Which is right for my mk2 172?
What is the internal diameter of the inlet pipe supplied with the kit? I already have a Hillpower cold air feed so it'd be great if that fitted straight on - never going to be that easy though! Or perhaps the BMC pipe would fit onto the Hillpower scoop?
Believe you can use it without the inlet pipe, although that's sub-optimal?
Cheers,
Gareth
Cheers,
Gareth
