Bonjour
Car  Clio Cup
Hey up , Had my little 172 a while , just taken/smashed it off the road ill be milling about mainly in the for sale/Wanted sections if im honest Im Stuart From Just outside Liverpool nearly 30 , upsettingly , HGV mechanic so have an awesome space and 2 post ramp in work for playing , here are a couple of pictures , before and after ethel.webpethel2.webp
cheers Gents
Was Making a Sat Morning Maccies Stop , And the Slip Road Contained sheet ice , the ABS s**t itself and the pedal went solid , tried cadance braking but it was ALL too late , hit the curb and post on the left , twisted a chassis leg bent a load of suspension bits , but alas , its off the road and in the process off a re-build - Trophy front shocks , seam welded shell , rose jointed front wishbones and rear beam ............................... To start with so fat
Hello again. Well 7 years since that one. I've had a a few clios and moved to the Nürburgring for a while then moved Munich and I'm looking for a 197 for my next ringtool. So hiya to everyone again
How does one move to the ring? Are you in the car business?
Sounds epic!
Sounds epic!
Yeahhhhhh I'm a mechanic, was workin in Belgium so stayed there at the ring every weekend, got to know a few people and found a job.
It's awesome, but the novelty wears off fast, having the track on the doorsteps amazing but the place is empty in winter, there's f**k all else to do, aside from the track and you soon get fed up of every c**t and his dog revving their car past your window at 8am every weekend morning
Hence the move to Munich a 3/4 hour drive. Close enough but far enough away
