Bosch Oil Filter - Sump plug washer
IIRC i think its only the renault ones that come with a sump washer, they normally give you them free if you go to renault
And you need one with every oil filter even if its not reanult yer?
Could I not just keep the one from my current oil filter?
cheers
doubt it very much, as said sealing ring is loose change anyways.
i have just got a bosch one, no washer....they aren't the crush type so you may get away with re using the current one, however for the sake of a quid just buy a new one. if it leaks after you re used the current one then it means dropping the oil to replace !
