Brake advice for 182
Car  Black 197
Hi all i been in contact with K-Tec in regards to new discs & pads all round, they have recommended these :-
Front :-
http://www.k-tecracing.com/show_product.asp?id=1148
Rear :-
http://www.k-tecracing.com/show_product.asp?id=1574
Is anybody using this setup and how does it compare to say standard discs ? I dont track my car so would be for road use only, Now i will need them to fit them for me as dont have the required tools (long story) but they have quoted me £50 + VAT for front fitment and the same again for the rears..
Is £100 + VAT for fitting discs high ?
How about Rentech ? I've checked there site but see no products is it best to call mike and see what he's got to offer ?
Thanks guys input will be appreciated
Id go for some brembo HC or max discs mate. The HC's are around £65 for the pair iirc. If you can source the parts seperatly you should save a few quid and i think you can find somewhere cheaper for the fitting if there's no way of doing them yourself
the rears need bearings pressing in do they not?
In the link to the rear brakes K-Tec state the bearings and abs rings are already pressed/fitted so shouldnt be a problem i hope
I been K-Tec before so maybe a chat with them and my membership card on there desk will shave a few pennies off ? Need em doing bad as im on original discs and its showing 43K on the clock lol
If thats the case then surely it would be worth spending the £100 on a jack and some tools to fit yourself?
drilled = pointless
the fronts are a bit pricey to be honest, you can get brembo HC and DS2500's (the best all round pad there is IMO) for the same money
rear go stock OE stuff
and fit a set of braided lines, that's one of the best things you can do to the car
drilled = pointless
Thanks Fred much appreciated mate and to all others who had input, made my mind up now so will get done this week
Can try Mark Fish, not to far from surrey either!
Having my brakes done in a couple of weeks.
