Brake Bias Valve
i'd "T" the 2 lines into 1 then into the valve and "T" them back into 2 again
but that's with the ABS in the bin for obvious reasons
i run a 2 port master cylinder with 1 line tee'd off the master going to the fronts (direct) and the second line running inside the car into a bias valve then Tee'd to the rears with the ABS pump thrown in the bin
