am attempting to renew the fluid, tried the eazibleed kit but couldnt get a seal on it, so am doing it the old fashioned way!
when you pump the pedal down to expel fluid, the haynes manual says to tighten the nipple each time before you release pressure from the brake pedal, in order not to let air in - is this the same procedure for renewal of fluid? do you follow this step, as i know haynes do sometimes overcomplicate things a bit!
