i need to fiil the brake fluid up were is it to fill it ???? sorry i am a amature:S
B byers clio 182 Aug 28, 2009 #1 i need to fiil the brake fluid up were is it to fill it ???? sorry i am a amature:S
Sym0n Bus w**ker Aug 28, 2009 #2 If stood in front of the car it's in the rear left corner. You might need to remove the engine cover to get to it easily, if you have one fitted.
maynard ClioSport Club Member ph2 172 track car Aug 28, 2009 #3 yep, also so you know it's dot 4 fluid that is recommended!
I iimushroomzii Toilet roll king Transit Connect. Aug 28, 2009 #4 You shouldn't need to fill it up unless you've got a leak,or taken calipers off etc. It may be low because you're brake pads need replacing..
