Brake line started rounding off
As above, I'm trying to change my caliper but the brake line will not budge. I had this problem on the other side and it started to round off, but I managed to get some grips on it and sorted it out.
Come to change this side and it will not move at all. The nut thing has started rounding - it's that tight.
Any ideas how I can get it off? I do need to reuse it.
The lines are Goodridge braided.
I would say normally siezed nuts and bolts respond well to a bit of heat but that is obviously out of the question in this instance! Looks to me the only option is going to be a good pair of mole grips! You're going to chew the end of the hose up but I don't see any other option! :(
Brake pipe spanner..? They're very soft pipes/connections normally...
Got more surface area in contact with the nut.
It's rounded loads so I think I'm just going to take it off at the line, leave it connected to the caliper (bin both) and buy a new set. f**king Clios.
You'll get it with some mole grips but the end won't look good. Possibly good choice by replacing the line too!
