brake pads
Car  Burgandy 174 sport t
how easy are they to change on a 02 plate dci, Ive dont the suspension in 2hrs so pads should be no prob eh!!
anyone got any pics too look at as i dont have a manual??
easy, take the wheels off (pop the bonnet and undo the cap on the master cylinder) undo the bolt on the bottom of the caliper (located behind the caliper) 16mm or 17mm (cant remember) youll need to hold the nut just inside the edge of the caliper with another spanner (again witha 16mm or 17mm spanner)
lift the caliper up
next is the hardish part, you have to push the piston back into the capiler, i use a wheel brace to do this and lever it off the opposite egde of the caliper.
slide in the new pads (copper grease the back of them to stop them from squeaking)
drop the caliper back down
replace bolt and tighten
put wheels back on
remember to replace the cap on the master cylinder
remember to pump the brakes before you dirve anywhere!!!!
That last point is the most important.
To get the piston back I used a large G clamp with no problem.
Best geting somne to help you hold the caliper when you have taken it of whilst you replace the pads as it is difficult to hold the caliper and push the piston in.
The old Clio Haynes manual tells you how to do it but when you get the wheel of you understand it better than nay manual can explain.
Its an esay job even I could do it.
EDD
A spanner placed across the piston will allow you to simply squeese it with your hands back into the caliper.
