Failed MOT on a rear pipe from load sensor valve to drivers rear caliper. However ended up changing all the rear pipes which was not fun but managed it, and also managed to connect all four connection onto top of load sensor valve and get it remounted correctly (anybody whose done this will know its fairly awkward, anybody about to do it give us a shout for help and pics). Anyway everything is sound, however I think the load sensor valve is not set right, as I feel I am not getting enough brake force on rear (even though it went through MOT yesterday), which leads me to assume load sensor actuating arm needs adjusted. However this is meant to be dealer only job, which makes me want to do it myself. Anybody know procedure to set these correctly (this knowledge would be handy for people lowering their clio also). I am assuming tightening it causes more rear braking force (as it pulls arm in same direction as if the car was more heavily loaded?, any help
