Brakes squeeking when driving
Car  Dynamique+ 1.4
They stop when you apply the brakes but the front discs are squeeking mentally, what can i do to stop it?
you may need some copper slip/grease on the back of your pads as this can causing a squeal when driving worth checking and only 2.99 from the frauds
not sure if the discs have warped due to harsh braking.. what my dad has said to me anyway?
You cannot warp disk.
what happen is ou've stopped dead on hot brakes and left yourr foot on the pedal the pads have stuck to the disk and left deposit so the disk is uneven as such.
Sound like just needs copper slipping up a bit.
ahh good so its going to be cheeper to sort, where do i get this copper slipp stuff from then?
from a decent motorfactors 7 quid should get you a huge tin.(which should last forever), halfords do the big tins but they're pretty expensive from there. they also do a tube, only small for about 3 quid.
apply a smear to where the caliper parts meet the back of the pads, and a small amount on the pad runners (where the pad moves in and out), careful not to get any on braking surfaces though.
