Is my brakes knackered?the make a grinding sound at low speed but the stop ok pads are only half worn about 3 months ago had the checked.Dose anybody know where i can get wheel bearings?rear ones for a 2001 1.2.thanks
Back wheel bearings need changing sounds like gravel in the back wheels the noise is coming from the front but goes when there warm i guess after a drive
motor factors will stock the rear wheel bearings. but id get a garage to do them unless ur handy.
brakes. i would have the fluid changed. if this does not improve it then have all the disks and pads checked.. if there ok then have the garage check the servo , master cylinder etc
