Braking at slow speed Help !!!
Car  clio 182 FF
As I brake at low speed it feels like my abs is kicking in then it's fine what has happened to my brakes?
Ali has had a shot and he has noticed the same thing/
It's like braking on ice, but on normal driving it's fine the brakes work fine but when you are braking to a stand still thats when it happens
can anyone help????
Failing that, I'd say check your front discs. I had the same thing happen to mine and it turned out the inside of the discs was corroded - believe me, it felt a little scary when I found out about it at 60 odd when someone cut me up and the brakes didn't work!
MB_182
MB_182
wont be that matey he's not long fitted brembo max discs;)
Fire it into reno danny, i think it's something to do with when they swapped the hubs over!
Sounds like you need a new drive shaft to fix a ABS ring TBH. get under the car see if the Cog type ring is free spinning.
might as well get a new shaft. if its feked ( spinning) then u will need to weld etc
MB_182
cheers for replying for me dont think i'll ever need to reply to anything anymore since your on here now lol
