Quite a lot when I brake I hear a scraping sound like it would be the brake pads which are knackered, but no - I got the brake pads/discs checked out and they are fine.
Do you feel anything on the brake pedal? I'm having the same problem on my 172 but also feel the pedal vibrating. It's going into K-tec racing on friday for a check over.
I sometimes get this as well. Brakes really well on smooth ground but feels like it's biting and releasing (sort of sounds like the pads are scratching around for grip on the disks) when braking on poor or very bumpy road surfaces. That said, it still seems to pull up to a halt in the same distance, just a bit scratchy in the process...No idea why
if its cold or been raining recently they will ne noisy and scratchey from cold ..... what pads have you got fitted ? have you inspected the pads to checked for a wedged stone in there or the like ?
I'm on standard pads and disks...never considered a stone but suppose that's feasible. The English weather/cold pads explanation would also makes a lot of sense.
Well,my 172 went into K-TEC 2day and it turns out that i need a new driveshaft. The ABS part on the drive shaft has broken off and that is what i can feel on the pedal when braking.
