Branding of super-unleadeds and outputs
I use V-power.
I get better MPG and (un-related to the video) i felt the car pulled better lower down the revs, not talking massive amounts but noticable.
I find a tank of Tesco99 doesn't last very long.
You need to fill up with the same higher octane fuel a few times to feel the benefits i think.
noticed the prices really creeping up, was 111.9 yesterday and now 112.9 for tesco 99 ron.
seems evry time i fill up this last few months its gone up a few pence.
I always run mine on standard dinosaur juice. But i'm considering upgrading to bp ultimate as there's one reasonably close to me. Although it's only small so runs out of the ultimate-dinosaur juice quite quickly, forcing me to use standard again :(
Plus the 10-15p extra per litre puts me off a lot. Is the minute gain in mpg, performance and cleanliness of the fuel really worth it??
I hopefully can add something useful here.
It depends entirely on your car lol. 172/182 it made no difference whatsoever running on normal vs super. However, in the golf, I've done 2k miles in 10 days on motorways with cruise at 75mph.
Normal - 28mpg
Tesco 99 - 33mpg.
All other variables exactly the same, performs far better on super as well :D
Normal - 28mpg
Tesco 99 - 33mpg.
+1 on my GTI, it love BP and shell petrol, any supermarket pisch and it is very rough!! Thats not even Super Petrol etc
I nearly ran out of fuel the other day and no garage nearby had Super Unleaded at the time. Had to put a tenner's worth of poverty spec fuel in and it felt like it was running on weasel wazz. Can definitely tell the car's not mapped to run on it.
I had to drive really slowly too :(
What map is your car running then Darren?
Can't really answer that question. The car's not N/A anymore so it's a pointless comparison lol.
EDIT: But one thing I will mention is that it definitely idles better now than it ever did before.
I like to use BP Ultimate as much as possible. Having said that, I find the local garage to be hugely overpriced; having filled up with ultimate at other BP garages around the midlands and found prices to be quite a bit cheaper!
Filled up with v-power today, following the praise it seems to have received :approve: At 111.9 a litre, I think I could be sticking with it tbh! :D
tesco's 99 i believe has 5% ethanol/bio ethanol in it, i maybe wrong
It does indeed, hence a slightly lower calorific value than other 100% petrol fuels- thus needing more of it for the same power output (less MPG).
Shell used to be the only ones who would gaurantee (and provide a test certificate) that their fuel was 99ron at the pump- although if you get and old batch, chances are it's lower.
I always use V-Power or Tesco 99, generally see 32mpg with V-Power, and a few mpg less with Tesco.
I'm not very clued up on the Ronald management, but I'd have thought it should have knock r****d, so you will loose power with a lower RON fuel (all be it very little).
hmmmm i never understood ultimate... its more expensive then Vpower, and only 97Octane :S
just to add to this, when i work for drivers dream days (in my spare time) we run all the cars on normal bog standard petrol, only the high speed cars (scooby STI's and Evo's) get super dooper fuel
so thats
Astons - AMV8's + DB9's - normal
Ferraris - 355's, 360's and 430's - normal
Lambos - gallardos, murcielagos - normal
Porkers - lots - normal, even the turbos
TVR's - normal (when not broken)
Bentleys - normal
you get the idea, but then we do do a few thousand litres in a weekend!
Fred- The Bentley motors deffinately don't like normal fuel- V-power all the way, knock control is quite heavy on them.
i run mine on normall unleaded, never really noticed much difference in super
Yeah same here.
Used to run the 182 on Vpower all the time when the fuel prices for super unleaded were in the 95p region but because I found milage/perfromance noticeable and the prices are now a bit too steep for my small pockets I've decided to put in normal unleaded.
supercars don't need it, we've never lost an engine due to fuel
we've done 15 sti engines in just over 12months (not just fuel related) they get the superdooper because they are flat out all day
i dont think unless your car is turbo its worth the money
this country is f**king us over enough with petrol prices
