A little update. Blinged the ecu mounting up with some fancy anodised cups that I'd got lying around. The plate and ecu are now fixed down.
View attachment 129636Had a little play with some stuff that I borrowed off
@Panda today. This consisted of pms caliper brackets, brembos and 300mm discs. The findings are that I can run them on my cup turinis without the need for a spacer, which is happy days. Different story with the superleggera's though!! Here's some pics so you can see what I mean.
View attachment 129638 There's a good 2-3mm of spoke clearance and caliper to wheel clearance here.
The same can't be said for this though!
View attachment 129637 It looks like I'd have 2 options here. Run a 5mm spacer and machine the calipers with more of a radius to gain clearance. Or have some custom ally bells made to run a 2 piece 295mm disc, machine the caliper to sit slightly lower, with a radius for clearance and run a 5mm spacer.
The scenic 300mm discs are heavy as fook as well.
Worth the hassle for an extra 20mm of brake disc size? I'm not convinced.
More to come.
