Buggered bearings?
Car  Renault Clio S
Think I may have worn wheel bearing(s) on the rear, but just want to ask what the obvious signs are. I haven’t jacked up the car yet to see if there’s any play/wheel movement, but a few weeks back a droning noise started to become audible above 70mph. Now the noise appears between 30-40mph, but quietens down thereafter until to you hit 70mph where it becomes quite loud. Would the droning noise from a shagged bearing be consistent or fade in and out as described?
Ta muchly.
sounds very much like wheel bearing. Don't fit cheap ones, you'll be doing the same job again a few weeks down the line
