rich_1989 Car 03 RS clio 172 flameR Mar 15, 2010 #1 as above, there is a notch of arch liner that sticks out and when my coilovers go down a bit they rub on the wheels. ben says take a hammer to it, is that right or will it damage somthing?
F Fred@BTM Car Lionel Richie Mar 15, 2010 #3 the bumper bracket is behind it, needs bending out the way
Jonny1*2 Car Golf GTD Mk7 Mar 15, 2010 #4 Fred@BTM said: the bumper bracket is behind it, needs bending out the way Click to expand... ah he means the cover for the bolt? just cut it off then?
timmyd Car 500 Twinair Mar 15, 2010 #5 You'll need to cut the arch liner bump, and behind that is the bracket which you can just flatten it very carfully with a hammmer.
rich_1989 Car 03 RS clio 172 flameR Mar 15, 2010 #6 sound will sort it out tonite then, is that going to allow a bigger drop or will i still find the tire rubbing?
