C4 mist washer jets aiming far too low?
With the car not moving they should be spraying all over the windscreen.
I've done the swap on my ph1 and trophy and there all good.
Sounds like your washer pump needs replacing mate! Not expensive, jist awkward. Make sure to get a windscreen puller!
Are the hoses on properly? Take the pipes off the jet and test to see if its powerful. If it is, then its the jets, if not then its the pump.
Ive found after buying a few sets off ebay that there is loads on there but only 1 which states its genuine the rest seem 2 hit just under the wipers
Doesn't specify on the eBay listing whether they're genuine Citroen or not. Didn't think to check...
Tried adjusting with a sewing needle but nothing budged, so heading towards going back to normal jets...
Get some genuine ones. Type in genuine.
