caf and acoustic valve removal 182
Car  MK5 R32
I've just got a ITG panel filiter for my 182, been told to remove the CAF and acoustic valve to get a better sound, anyone know how to do this quickly, or is there a guide/ link of how to do it, dont want to take my front wheel off if i can help it lol. cheers
You cant help it. Needs jacking up on passenger side, wheel off, s**t shields out horns out, Acoustic valve removed unplugged and hole bunged on manifold and in the words of haynes refitting is the reverse of removal lol :cool:
i did all mine with wheel on :) just jack it up unbolt arch liner thenunbolt the horn which takes the acoustic valve off rebolt horn in place and ull see a small rubber hose about 5mm diameter push a bolt in the end of it then zip tie it in then job done and that rubber hose gos to your inlet you should see it near your throttle bodie
cheers guys ! :) Im just going to remove the valve and leave the CAF. whats best to block the tube after you have removed the valve ?
It's much easier with the bumper off, but still an easy job mate. Follow the cliotrophy guide. Don't forget to tape up the wire you'll remove.
its not really worth doing tbh no. i have but no real difference at all but i wasnt expecting it. its possibly free'd up the revs a little and a slight bit more noise. nothing to shout about.
also saves a tiny bit of weight and one less things for the electrics to power.
Cheers. That just about sums up what I thought. Think I'll give that one a miss!
