Calibrating 172 Throttle pedal Help.
Car  1998 BMW e46 323i
I've rec'd a replacement throttle pedal, and I thought the Haynes manual covered the calibration process, it just covers the calibration of the throttle body.
Can someone enlighten me please?
Thanks, John
Plug it in, ECU does the rest. It programs the throttle stops everytime you turn the ignition on. Although I don't think it has anything to do with the pedal, just the body.
Ok cheers, I've installed it already having done loads of searches and found nothing about installation. Hopefully my starting woes should be sorted having replaced this and the t'body.
starting woes ?.........whats it doing, or not doing ?......TDC sensor is the usual culprit to starting problems
