Call of Duty Modern Warfare
Managed to get a decent trio win yesterday. The game had been brutal recently. Enjoying the pkm which seems to have become meta pair with a single skykov pistol it's pretty good. Edited.. Managed to t**t myself with my own betties....standard.
Well played on the buy at the end.
I did chuckle, bush hopping for the first three minutes - standard 16v_er play 🤣
And your mate blowing up your BB was gold 🤣
How has this guy got 19 kills on a 0.61 kd? He's on PlayStation so I assume his ability to cheat is limited but I pretty sure he pre aimed through a sodding rock (not bush for a change)
I like the banter in game. The mechanics are good. But overall the game is toss. So many iffy moments that make no sense and every kill questionable with cheating on all formats.
My cod mw disc broke for some reason so I thought I'd give the other one a go.
It's a bit more arcade style which I don't prefer... although I have discovered playing TDM with only a knife, that is very fun
Started using the Xbox elite 2 controller the other night to improve my movement, so far t has actually made things worse, hands completely spaz out and I push all sorts when in a gunfight [emoji23][emoji23][emoji23]
A friend of mine said it took him a couple of weeks so I’ll stick with it!
Anyone else had this?
😂 I’ll check what I’ve got mine set to tomoz for you
I’ve also brought the scuff back paddles which make them easier to use and are made of metal so feel much better to press so to speak.
takes a while to get used to it but it’s 100% worth it in the end should always have your thumbs on the sticks now
I was tempted by the Elite controller too or the Scuff one not sure I'd use all 4 paddles mind maybe just 1 each side for jump and prone. I'm guessing the current buttons still do the same thing but you just have the option to use paddles if you want.
Yes, I have the Scuf prestige. As @withoutabix said, takes a while to get used to, but once you’re “relearnt” the muscle memory, it makes a huge difference to game play. At least it did for me.
You can also only map two of the paddles if you want, and the buttons you map stay working, so if you “forget” and do revert to pressing a button and not using the paddle, it still does what you want as opposed to stood in the open flapping about doing nothing.
Flapping about doing nothing is what you are good at @Cub. 😂😂😂
Tried high alert when the pros were saying how good it was. Pretty sure it flashed and I died instantly. Went back to ghost lol
