Cam Belt problem
James5_GTT
Car  R5 GTT
Well had a recent problem with my R5 engined 172 which turned out to be timing related so i got a new cam kit and hired the tools to do the job. Now I started the car for the 1st time tonight and let it idle for 30 mins when all of a sudden a strange noise and I discovered that the cam belt had eaten one of the pulleys:eek:
Here's a pic of the mangled pulley
It's a little strange as the belt tightness is controlld by the tensioner pully which all markings are aligned as supposed.
New Pulley according to my Dialogys - 77 00 108 626 PULLEY LA 42.76
Any advice?
all i can think is maybe the idlers were fitted with the spacers wrong?? the lower idler is meant to have a thicker spacer than the upper one. that pulley looks like the belt wasn't central. does it spin ok?
When you say spin is it supposed to spin when the cam belt is all tightend up??
I am thinking I have used the incorrect spacer and bolt these are the only parts I also didn't replace with new:(
Looks like the pulley has stayed stationary when the engine is running and the belt has just melted it.....
I was just about too say that... Looks like the pulley was stuck and just melted?
What are the actual differences between the kits though?
one of the ph1 pulleys has a smaller hole and the spacer sits behind rather than being interted. if you used a ph1 spacer on a ph2 pulley it wouldn't center and probably lock up solid...
ahh...
I can remember when getting my cambelt kit the guy mumbled something about different pulleys blah blah blah!
I am runnung a phase 2 engine but converted to run phase 1 cable throttle body, etc..
The pulleys I replaced them with where exactly the same I wish I had kept the old ones now I just chucked them away :(
get some pics up of the cambelt area of the engine
which idler is it also? the one below the tensioner or the one just across from it?
I am now thinking back and don't remeber the pulley spinning freely when the cambelt was fitted!
it should roll freely!
didn't know there was a difference in cambelt kits... dodgy!!
The cam belt I am using is a 77 00 113 559 TIMING BELT but my dialogys also list a belt under ref 82 00 098 343 BELT which is also a cambelt.
There are no different options for the pulley I need
& more pulley is stamped 77 00 108 626 which is the same as my dialogys.
OK looks like i need to try a load of pulleys then
they're the same apart from the 1 pulley, from memory the phs2 cambelt kit idler pulley doesn't fit the phs1 spacer, its been a while since i've done a phs1 172
pulley 8200483288
spacer 8200607654
bolt 8200648631
thats all for a ph1 172 idler pulley (the one oppoiste the tensioner pulley)
phs1 cambelt kit complete 7701476674
for a phs2
pulley 8200483288
spacer 8200607654
bolt 8200648631
cambelt kit complete phs2 7701476675
so cambelt kits have different part numbers, but the parts individually are listed as the same, renault, gotta love them
edit just checked the lower idler wheel also, this is the one that's different
phs1
pulley 7700107150
spacer (2 options listed)
phs2
pulley 8200064664
spacer - no spacer listed
