Cam Belt Quote, £120
Got a quote off my local garage, he said he'd do the belt for around £120. Is this a reasonable quote or should I look elsewhere.
Sounds too cheap for a garage!? :S
I could recccomend a guy I use, he is based between Alfreton and Shirland.
Just make sure they put a cambelt KIT on, not just the belt. Maybe a service. up to you and depends entirely on what the car has had done in the past.
KK buddy, I had it serviced today but didn't think about the cambelt till after I'd had it done which is when I asked him. Thanks x
I have a receipt for the water pump just before I bought the car last year. So just cambelt kit and aux belt? Cheers
id still get it checked, i made the mistake of not checking mine before i put the engine in and its fucked lol, i think for £120 ur only gettin the belt unless they charge less than i do for labour and im cheap :O
if its had a water pump last year, it would have had a new belt fitted unless the guy was a complete plank and put the old belt back on.
If your not sure and want piece of mind that its done then go for a cambelt kit and aux belt(s)
pretty decent, just ask to make sure it has a new tensioner too (they're not plastic like the 172 ones so often not replaced if low miles) which should be fairly cheap.
