cam belt
Car  iceburg 172
was driving the other day and my cam belt tensioner has perrished away causing the cam belt to slip and knock the timing out.....
sooo any idea how much im looking at for new tensioners, cam belt and labour?
cheers Dean
I wouldnt bet on it, Have you had it checked out dude?
But cam belt tensioners and labour will be about £300 private i would say, not sure on renaults prices.
Try
Barry Plant and sons Garage.
01869 322234 - Victoria Rd, Bicester, Oxfordshire OX26 6PB victoria road
Neil knows how to do it and Should give you a good price.
say james off cliosport sent you.
Just bought the cam belt replacement kit from Reno, £90. Not sure that has everything though...
cambelt kit is £150
aux belt kit is £107
special tools are required
your clyinder head will be damaged
you're looking at about £1K bill unfortunatley in total by the time the head is repaired
oh and you need new cam seals and new head bolts and gasket set
ouch for this guy
hope it turns out not so bad mate i get worried about this happending to my clio 172
well jobe done..
was verry lucky as there were no damage to valves ect. so was just a case of changing the cam belt and tensioners,
charged me £110 which i thought was a good price:)
was a mobile mechanic from swindon, family always use him he always gives good prices and is verry good at what he does.
This happened to me on my 106 xsi... was lucky enough that the belt didn't jump any teeth, just went horribly loose. No other damage.
