cam cover oil leak
Car  200bhp 172 cup
I thought i had the common oil leak from the cam cover and on closer inspection it turned out to be the breather assembly leaking thats bolted to the top of the engine cam cover and oil seeps through the gasket so an easy repair and id recommend for all those with the same problem to look here first, just remove the inlet plenium and its there:) .
